1 - 9 of 9 Posts
I just replaced an o2 sensor in a friend's 2001 Tacoma reg cab, 4cyl. 5 spd. It fixed the 'check engine' light but on the way home he said it was missing badly.
Could it be that driving it while running lean (bad o2 sensor) could have goofed up the plug(s)?
I don't think that my putting on a different o2 sensor (came from a different truck) could cause it to miss like that. You would think that if the sensor was bad or malfunctioning that it would kick on the check engine light again.
Thoughts, suggestions????:confused:
Vinnie
[email protected]
WTF? If it's not the plugs I would check the coils/wires they don't seem to seat very well and can back off. That is something I have never experienced but have heard happening to a couple people while wheeling. good luck:confused:
I had a wire sit about 1/8" or more above the surface but it was running fine when I discovered it and pushed it down.
Leonel said:
Did you use a new grounded O2 gasket ?
Never heard of that. The gasket didn't even come off. I just took the old one off and put the new one on. Sealed up great.
Besides, it cured the check engine light problem. I think I will run the self diag tomorrow and see if the code still flashes even though the 'light' isn't on.
I think it's prob the plugs though.
1 - 9 of 9 Posts
