1 - 3 of 3 Posts
Looking at getting into a little crawling, very little knowledge on it, needing a little advise on a rig I am looking at purchasing.
95 Bronco with 72 ford front clip bolted on, 2001 F350 front and rear axles. 95 EFI 351, transmission and t-case. Rear end look like they just bolted Axel to stock springs, front look like a bad install job, original springs and radius arms that are welded to Axel and a 4 inch steel block.
Look like I will need to redo the whole front Axel install, and for the rear install some stouter spring.
Runs and driver ok, front drive line not installed, I think this will not line up right?
http://s1217.photobucket.com/albums/dd389/Barry_Warner/
guy wants $3500 for the rig. What do you guys think?
so far sounds like someones abortion. might be better off starting with a stock rig and building it yourself, might cost the same in the end.
1 - 3 of 3 Posts
