1 - 9 of 9 Posts
Ok so I am running 39.5 Iroks on 15" rims..I am purchasing new beadlock rims and debating on whether or not I should jump up to a 17" rim on my FJ40. Just wanted some insite on whether or not its really worth it (new tire purchase and all) to make the switch?!?
IMO with that much sidewall a 17" rim makes a difference. I hate blowing inner beads and too much tire roll. I wouldnt mind 20" on 42's but the tire selection just isnt there (Krawler, Maxxis, ect.).
I saw a pic of a guy on here awhile back and he had 44's on a 15" wheel, with a giant rip in the sidewall, that is what made me choose 20" wheels for my 49's, I was happy and didnt have any problems, the rim soaked up alot that the tire would have had to otherwise, I guess I am saying that since you are going to new tires I would go with the 17" wheel, good luck man.
DUBS on crawlers!! lol BLING! BLING!
Depends.. Are you at the limit for your axles, meaning you'll likely have a new bolt pattern when you go bigger?
If so, I'd save the cost of new tires, too.
If not (you've already got a 60 or something), then yeah, it'll pay off later.
Just my $.02
Wish I could say I had D60's! but i have longfields in front and stock landcruiser axles in rear!
You should think about how much sidewall your going to expose. There is a certain amount of to little and to much. 17's I think would be a good fit but what others have said be careful of your choice it may bring linitations of choice of tires and or change of axles/bolt pattern etc. Its the pits to buy something only to find out later that you have to change something else just to make your new purchase fit.
I got 39.5's on 20's I have been currently running 6 psi to get them to grab enough on the rocks. kinda sucks when you want to go fast because you can bottom out the tire on the rim pretty easy. I would step up to a 42" but I am not going to run radials or buy another set of double beadlocks just to get them.
1 - 9 of 9 Posts
