1 - 11 of 11 Posts
hi im setting up my gears and would like some help
here is the pattern at .014 pinion shim and .09 backlash
where do i go from here should i use a thicker or thinner pinion shim? ive never done this so any help is appreciated
thanks!
heres .011 backlash and .018 on the pinion
also its on a ford 8.8 with a spool, 90% street/ 10% strip driving if that makes a difference
I would have tired .005 more on the pinion - but its close- also if you can try dabbin the brush equally and its easier to read that way -make a picaso with don't brush it on- Jess
Discussion Starter · #11 ·
nice thanks, i put it back together with .020 and .010 backlash and with more resistance and dabbing the paint i could actually see a pattern
thanks a whole bunch!!
1 - 11 of 11 Posts
