I see Yukon gear are they any good,
Thank you, it is for a newer truck some places have them as a front and rear pkg, was going to a 4;11 gearYukon gear is complicated. They used to source from multiple manufacturers. Depending on what ratio and what axle, the gears could be made by totally different people. From Dana domestic to Chinese in my opinion you never really know what you’re going to get from Yukon. not sure if that has changed.
if I was building a Ford axle, I would probably see if they are available from Ford
If that was a factory option gear ratio, it may be cheaper to get a takeout from a junkyard then to re-gear what you have.Thank you, it is for a newer truck some places have them as a front and rear pkg, was going to a 4;11 gear
I tow heavy so wanted a good gear for the rear axle,
I think the Rear is a Dana 80,ever thought about using OEM Ford gears? i know you can get OEM Dana gears which are suppose to be much better than the aftermarket Dana SVL gears. think D60 reverse rotation 4.10 is 76159-5X. not sure what Sterling gears part number are
i will say the Yukon install kits i used were great. the USA Standard kits are similar but use Koyo instead of Timken and have some less selection. Amazon is a great place to get them cheap, they commonly are on sale
will probably want to decide if you want to use 10.25" gears or 10.5" gears as there pros and cons to both
unless its a Dana rear axle. im not super familair with dually axles
