1 - 11 of 11 Posts
Its time for me to start mine - it will be a total tube frame 4 1/2 seater -2 x.120 main 1.500 .095 sub braces - 4.3 vortec- ultimate marlin -d-44, 4 way steering - the diff's i'm thinking to roll them almost up side down so the diff cover is to the bottom- wep like a 2 1/2 ton rockwell- for 2 reasons - i can gain 2 1/2 inches ground clearance and i can run a driveline brake off the pinion along with the 80 degree c/v off the now bad pinion angle - its a little out there but i think it should work for my needs- oh yeh the driveline now will be completly out of the way and the t- case angle will be sweet- along to the rest- 4 link up front with nitro shocks about 15" stroke - rear should be a 3/4 eliptic - wheel base of 98" and weight around 2,500 along with 39.5 swampers- so is it a good start? Jess
How ya gonna get em to oil with the pionion verticle?
oil is not going to be an issue - will have an easy alternative - seals and there own resevior be cause we can! thanks for the input- and spoony bitchin silly neck- well i know where you got that- give me c all silly- we need to get jimmy's going - Jess
oh yeh the moser axles will have the super joint rated at 280,000 tesil - extreme huh! its a smaller verison of what i really would like- 56" monster truck goodyears - who can afford that- it should do well in our snow out here too- the ol cepeks are waitin -
Originally posted by onetoncv:
<STRONG>oil is not going to be an issue - will have an easy alternative - seals and there own resevior be cause we can! thanks for the input- and spoony bitchin silly neck- well i know where you got that- give me c all silly- we need to get jimmy's going - Jess</STRONG>
Damn, here I was hopin' you'd tell us how <IMG SRC="smilies/wink.gif" border="0"> definatley sounds cool though
Sounds neat man, so you're gonna put the CV end of the driveshaft on the pinion, and then a disc brake on the t-case?
If I were you I would go 2.5ton militaries. They would be sufficiently cheaper than d44's and with the extra $$$ you could afford 44" Boggers. It would definitely add weight to the vehicle, but it would be low, so you would have a better COG.
Later man!!!
PS> i will prob call you next week about my rear shaft...
Discussion Starter · #9 ·
the 80 degree c/v at the diff- and also the rotor off the top off the pinion also - kinda unique- the pinion seal will be on the top pinion brg- inside to have a resevior for the pinion brg- on top- i'll get pics when we get to that point - Jess
sounds sweet jesse, cant wait to see it. and yes we do need to get goin on my shizit, mr sillyneck was telling me about someone named abba with a rear end i might want, maybe u know him ! jiMMy
1 - 11 of 11 Posts
