I acquired front and rear Currie Rockjock 60's a short while ago. They are built well since they came off an ultra 4 racer. The front has an ARB and the rear has a full spool. Both axles are running 5.38 gears with CTM 300M axle shafts and u joints. The bolt pattern is 6 on 5.5
I bought these axles off Craigslist and the previous owner bought them off the people who had them on a ultra 4 racer.
These axles are complete minus the calipers and rotors.
I have researched every where to find what calipers and rotors I need. The guy I bought them off didn't know anything about these axles let alone anything jeep. So he wasn't much help.
The measurements I have are as follows:
Front axle offset - 3 inches. (From wms to caliper bracket)
The mount center is approx. 5 1/8 inches. (Center of caliper bolt hole to other hole center)
Rear axle offset - 4 inches
Mount center is approx. 5 1/8 inches
Current caliper brackets are welded on. All new control arm brackets will be welded on in time. I'm avoiding starting from scratch with new caliper brackets.
Notes: These are going under my 2005 LJ rubicon. I plan on running 40's on beadlocks. 4 inch teraflex lcg long arm kit with metal cloaks front and rear.
Any guidance on a brake setup would be greatly appreciated.
Info I am looking for: what calipers and rotors fit?
