first set:
2.5 ton rockwell front(narrowed 7") toploader style
with one u-joint shaft,one standard ball joint shaft
plus two standard rear 2.5 ton rockwell axles(stock width) $1400.00set
second set
2.5 ton rockwell front axle (standard width) toploader style
plus two standard width 2.5t rear axles $1400.00set
third set:
2.5 ton rockwell front axle (standard) old style
plus two rears $750set
I will not mix and match only sell in sets as listed,no shipping pickup only!!
6- 46" michelin tires ,really good tread (4 are siped for traction)
fit 20" rim $500 set of 6
feeler:: chevy dana 60 front,passenger drop,4:56 gears,open,
matching corp 14 w/ gov' lok & disk brakes (not installed all new)
$2000.00
dana 60 rear ,chevy,8-bolt,3:54 gears 65" wide $300
4- 39.5 x 14.5x 15 IROK 50% tread, one missing a chunk out of side but still holds air. $600
all located in Farmington NM
[email protected] NO SHIPPING AVAILABLE!!!!THANX
second set
third set:
$2000.00
