1 - 16 of 16 Posts
Pull yours all apart, measure it, draw it in CAD, and post it up here for the next person to use.
You're retarded. You don't even specify what you're specifically looking for and expect everyone to just give you shit that they spent time and money acquiring?
Tell you what, send a donation to my paypal account and I'll send you everything I have. (I'm not saying if I even have anything or not.)
J. J.
Discussion Starter #5
I'm sorry, but I love when somebody starts a reply with calling somebody a retard and then follows with some shit like that. There is nothing to specify, if I get a DWG emphasizing the hub and spindle drawings I can pull dimensions on it. I'm not looking to rob anybody of something they spent time and money on, if its that important to them they don't have to send me anything. I already have files that were sent to me its just a PITA for me to convert them to something I can use.
Hell I just might, apparently its a bargaining tool around here. :flipoff2:
Not really, it's just that in the last 6 months I can think of at least a dozen guys that have posted looking for free cad files. And they seem to get offended when people don't want to share.
I'm sorry, its very rare that I will reply back with something as inflamatory as that. Its just that you were so vague as to what you were wanting and so smug about expecting it for free that I couldn't resist.
Ultimately, if you are needing dimensions on the spindle and hub I don't think anyone besides Ouverson has that and he's not going to give it to you because he makes his living off of keeping it to himself so you should start disassembling and get out the caliper which is probably how he got his dims. Why don't you post up your results for free when you're done? :flipoff2:
Why do you need those dims anyway? Trying to copy something expensive on the cheap?
BTW, there is a Catia file floating around here somewhere of a complete front axle but the components are not broken down into seperate assemblies and it is just external dimensions so it will not help you. I suspect that is the file that you are referring to that you have because not all cad programs will open a Catia file. In addition, since you seem to want a drawing file, I suspect you aren't actually working with real cad software anyway and just have something that will open a dxf which wouldn't convert an actual cad file anyway.
Finally, let me appologize in advance if any of these ASSumptions are false. But its not like you've given us any information to help us help you to begin with so ASSumptions are all we are left with.
Anyway, good luck. I think I may have the spindle bolt pattern around here somewhere but otherwise I don't have what you need.
J. J.
PS: The link in your sig doesn't work.
Discussion Starter #11 (Edited)
No hard feelings man, I'm actually in the middle of putting some kick ass wheel brake kits on the market and I needed to get my CNC guy some DWG's to do the first prototype's of the brackets. Rather than the hand-mocked stuff, gotta make sure it all fits.
Thanks, the bolt pattern of the spindle is a huge help! The brackets on the front are pretty trick and I want things as tight as possible to help spread the load.
EDIT: Does anybody know the outside diameter of the spindle as well?
Not to sound like an ass, but if you're building it for profit, you may not get much help.
Why can't you just measure it up?
Discussion Starter #13 (Edited)
If I get the spindle diameter then I have everything I need, and yes I can easily tear the axle down and measure that myself...
then get to wrenchin'... :shaking:
I'd think if you're trying to make a product for profit that you would not want to trust someone else's measurement anyway. Their mic could be off, they may not know how to use it correctly, or they could be doing speedballs while they take the measurement, all of which might result in a bad dim for you to go to market with. Then you'd be fucked because you didn't want to take a corner of an axle apart, something that I can do in about 10 minutes with an impact wrench. In addition, if your potential customer base sees this thread they may think, "Hey, if he's too lazy to take an axle apart to get the product right, do I really want to deal with him or trust his product?"
J. J.
Discussion Starter #16
J. J.
I have installed the rotors that we have for the kits and pulled measurements, the DWG's were for the CNC guy and everything will be tested thoroughly. Its not like I'm going to receive brackets or anything for that matter and not check fitment and do some hellacious testing.
1 - 16 of 16 Posts
