I need some quick answers so I put this here to get more views.
I am trying to get my front rockwell hooked up so I can put some rubber under there. Problem is that damn tierod is in the way. I know that I could turn the knuckles around to make it easier but I don't want to do that. I built these nice brackets so that I can get the links hooked up but it puts the lower links so high above the axle center line that I think I am going to have problems with the way I was going to do the upper link. I put that hoop in there as low as I could and was going to connect the upper link to the side of it rather than the top, like I did on the rear.
The bracket hole is above the axle center line about 6" and the spot where I want to put the upper link is about 6" above that. What do you guys think I should do? If I raise the spot where I was going to put the upper link is it gonna help? How high will I need to go?
Thanks guys I am planning on having this done by the end of the weekend so I need to get this figured out soon.
