twinpinion said:
Does anybody actually know the real answer to this?
Ring gear/Carrier bolts?
Carrier Bearing Cap bolts?
Ring gear/Carrier bolts = real tight with an impact and then wire them up
Carrier Bearing Cap bolts = really, really tight with a 4ft breaker bar and socket... The line up the wire hole with the extra little snug down and wire them in...
What I was wondering is how you would check the carrier bearing preload - would you have to tear out the bull gear pinion and then check and reassemble or is really good and snug on the side adjusters good enough....
I just ran mine in with the bull gear centered and the lash so it felt pretty much like all the other 3 chunks I had to compare against...
Matt
