1 - 12 of 12 Posts
I have two front Rockwell 2.5 ton u-joint style in great shape. One has brakes removed and welded dif.Both are set up for hydrolic steering and is avalable if interested.$1500 or $1700 with steering.Trades??
Wanted Ford front Dana 60
916-416-4549
There are in good shape you could bolt them in as is. I have put new rubber boots and new berings. 6.72 gears .Only one has spiders welded, but if you wanting to add a locker it would be no problem since the locker would replace the spiders any way.
1 - 12 of 12 Posts
