1 - 6 of 6 Posts
IH/Rover Moderator
The title and the question don't match. Do you have Rod ends or Tie rod ends?? There not the same!
get some TRE and be happy with a stronger more reliable end that gives you more angle of operation. Or just run what you have, I definatly would not add zerks that would definatly cause a strength issue
Come on man, would you drill a hole in an ungreasable Ujoint?? If they don't have the zerk they probably don't have a channel for the greece inside. What kind are they? Are they El-cheapo or what? Mine don't have zerks but they are chromemoly teflon lined(ie:self lubricating). If you don't know what you bought or aren't happy then send them back. From now on buy quality ends like QA-1 from a dealer. Check out racerparts wholesalers on the net <IMG SRC="smilies/rolleyes.gif" border="0">
1 - 6 of 6 Posts
