1 - 12 of 12 Posts
hello, getting ready to build my rear four link. i have 3/4 inch heim joints and missalignment spacers that reduce to use a half inch bolt. having second thought on this setup. worried about strength. anybody running this setup or had bad luck with the bolts breaking?
thanks
here is the plan...... 78 f150 . no dog house shortened wedged hood with all inner structure removed. rear mounted rad,battery, dual propane tanks, 60s, 203 205 doubler, 351m c6, cab cut off at bottom door hinges at angle, plated in with quarter inch to bottom of frame. no box shortend wheelbase, frame cut off at cab, back half tubed and tied into exocage. weight is questionable. tire size 40 low power 351 . maybe weight in the neiborhood of 3500 4000 #s
Even 3/4-16x 5/8 heims would be fine. 5/8 heims are stronger and a 5/8 grade 8 bolt aint gonna shear off!!
I hammer on my EB and my tabs are all 3/16 plate with 5/8 bolts, I weigh in around 5k. Nothing broken yet. Oh and i have wishbone upper links with johnny joint and they are 9/16 bolts.
How about using Rubicon Express Super Flex Joints. You can buy them weld on or as complete welded and built assemblies and they use a 9/16" bolt. Other parts are available for making the arms adjustable as well.
Discussion Starter · #11 ·
already bought this stuff really cheap on ebay, store name is real products. i think i will drill out my misalignment spacers to accept a five eights bolt seeing that i already have them.
Good luck with that...unless you have a lathe...most misalignment spacers are made out of stainless(very hard). This will be a bitch....go as slow as possible if your gonna try it....
1 - 12 of 12 Posts
