181 - 200 of 303 Posts
2002 March, Spring (april) , May I'm on the front cover of the april edition in my 2a 109!!!:D!
Land Rover Owner:
1998 October (2 copies)
1999 Full Year
2000 Full Year
2001 March, May through December
2002 March, Spring (april) , May I'm on the front cover of the april edition in my 2a 109!!!:D!2004 March, April
Land Rover Enthusiast:
2001 January, Sept through December
2002 Full Year Minus March
2003 Full Year
2004 January, February, May, August, September
2005 Full Year
2006 Full Year Minus February
Land Rover Monthly:
2007 January
Land Rover World:
2005 July
Two binders for LRE
Eight binders for LRO
All in like new condition with no stuck-together pages, they just need a good home: $20 plus shipping, or a 12 pack of Magic Hat #9 for pickup (much preferred )
located in 12846, i work in 12144... can pick up at either.
LR based Rock-Buggy project - For Sale
Hey guys,
I haven't posted here in at least a couple of years. Life has taken me in a different direction, and unfortunately I will not have time for four wheeling in the foreseeable future, so I have to get rid of my rock buggy. It is about 90% complete. It is in its third version, and has been up and over the most difficult trails in Moab in its second version. That was about four years ago.
I would like to get $5,000 for it, which is far, far less than I have into it in parts alone, let alone hundreds of hours of my labor.
Here are the basics:
The base vehicle is a 98 Disco. I have a clear IL title (I'm the original owner)
4.0 V8, ZF trans and LT230 tcase have ~150K miles on them. New head gaskets at ~120K miles. No problems, and only very minor oil leaks :D. I haven't started it since 2008, but there were no problems then. There is about 6 feet of the original frame left.
Highlights:
1.75 DOM cage
4-links front and rear with johnny joints and 12" fox coilovers.
110" WB (uses a stock disco rear driveshaft front and rear)
Toy diffs with ARBs F/R, 4.88 gears, 30 spline Rovertracks axles and Longfield CVs. Never broke an axle or ring gear in this configuration.
39.5x13x15 bias Iroks with at least 90% tread, no punctures.
Allied beadlocks.
Warn winches front and rear
Custom 8 gal aluminum fuel cell (uses stock LR fuel pump)
PRP suspension seats
DJ safety 3" racing harnesses
Recored and cusomized Discovery radiator (more rows)
Saginaw P-power steering pump
High-flow hydroboost brakes
AC compressor converted to Air compressor with all the goodies (tank, regulators, pneumatic switches for air lockers, etc.)
Rock lights
Swivels with high-steer (or as close to that as possible on a rover axle) knuckles.
Disc brake on T-Case.
Bikini top.
UHMW boat sides (not mounted in pictures).
I was in the process of extending the front end by a foot (done) and adding hydraulic steering (not done, have all the parts), as well as the dash (not done, have all the parts)
Lots of parts and spares:
PSC quick release steering wheel, Orbital valve, custom made double ended ram with PSC mounts. Warn hi/low driving lights, shit-ton of autometer gauges. Howe 3" aluminum power steering cooler (awesome). Front sheetmetal and hood, center console with f/r winch controls, spare calipers, pads, ujoints, driveshaft (maybe), knuckles, heim joints for steering, fuel pump, and probably more that I can't think of.
I hate to get rid of it, and I would hate even more to part it out. It is close to being on the trail and is very capable and fun to drive.
The car is currently not running, but it does roll so can be loaded on a trailer.
What needs to be done: dash, hydraulic steering, and plumbing for coolant, power steering, and brake lines. Might need another stick of DOM here and there in the front. Mount sheetmetal.
If interested or if you need more pics, please get in touch.
Alex
Any idea on the weight. Why doesn't it run? Has it ran since re doing the electrical stuff?
Last time I weighed it, it was 4,600 lbs. That was with more of the stock frame and glass, interior, and full front sheet metal on it. and me. Should be closer to 4,000 now.
If someone is seriously interested I have a four-corner scale and can weigh it as it sits.
It hasn't ran because I haven't run it. I modified the harness to remove all unncessary circuits (got it down to less than 10 IIRC.). I have notes on what I did. I did test it after the harness was modified and it started and ran fine.
It can't be started now because the all the underhood plumbing, main harness, and fuel lines have been removed. as mentioned, I have all the parts.
I also found more spares: set of exhaust manifolds, two y-pipes (both with o2 sensors, one with good cats, the other with gutted cats).
Gravity Works!
Dealership sign FS, any interest here?
I could post this in Misc FS but its more geared to you folks in here and ya might miss out on it if you're interested in it.
Anywho we're looking for $350 plus shipping on your dime. Does have a scuff mark on it that cost extra. :flipoff2:
Hey Alex,
sorry to hear that :(
I hope to see you again somehow, sooner or later, and wheel again :)
Hey guys,
Alex
Gravity Works!
I have great interest but my wife would kill me for buying it:flipoff2:
Chicken. You don't have any hair on your balls if you can't... Come to think about it, your wife has your balls in a jar don't she? :laughing::flipoff2:
You know you want it and someone's gonna beat ya too it. :flipoff2:
I was just reading your first build thread the other day. Gave me some inspiration to use the AC compressor for OBA on my D1.
Was wondering if you still had the truck, I guess so. GLWTS!
Thanks. I hate to part with it, but I just don't have time to finish it, or use it for that matter. It will make be a fantastic deal for someone.
