stock braking system on 80 toy ( to my knowledge) except extended brake lines.
when i pump the brakes(booster working) my rpm's drop, but only if i pump repeatedly.
is this normal for a toy?
my braking system has issues, that should also probably be explained...
when the brake booster is hooked up my pedel has no resistance at all, and the pedel goes about halfway to the floor then stops and won't go anymore. i can lock them up if i slam them on but when slowing down gradually i run out of braking power real fast (pedel won't go down further and im still moving).
when the brake booster is NOT hooked up the pedal functions normal except for the amount of force i have to put on it, but thats expected.
has anyone else experienced this with their power brakes? a fix or way to give my pedal some resistance?
