1 - 6 of 6 Posts
I have a set of 4.5" lift springs from Rubicon and the left rear spring is sagging about an inch and a half lower than the rest. They are set up as spring over and have never been wheeled, just used for mock up. Is this a common problem with their springs. If this is a common problem, any suggestions on alternatives.
I don't have a spring shop within 150 miles. I have not thought of swapping springs in different packs around. It's just a little dishearting to spend money on something and never get to use it.
I had the same problem with a 4" spring under lift. It sagged to one corner after about a month. I called them and they all but said tough shit as soon as they are installed they will no longer care. So I do not run them anymore.
1 - 6 of 6 Posts
