1 - 4 of 4 Posts
Discussion Starter #2
When you swap in your 63's if you plan where you want your tire to end up and what size you plan on running it shouldn't rub. I just moved my axle back a bit (I know, technical huh?) and with the rear bumper caps off of it already it doesn't rub in the rear at all.
Then when I SAS'ed the front I just moved the front axle forward. I did cut the front fenders off under the body line at an angle.
It mostly depends on how you set your axles up and where the tires end up/what size they are. Set it up how you like it then cut the fenders till they don't rub anymore.
There are at least a billion pics on my build thread and photobucket, check it out.
Discussion Starter #4
Thanks oober!!!!! I did go through ur pics but couldn't come up with any close up pics of the rear fenders. I did notice that you moved you rear axel forward versus moving them back or at atleast thats how it shows in the pics. I am going to reuse the same stock leaf postions that are on the frame and move my axle back at least 3".
1 - 4 of 4 Posts
