1 - 8 of 8 Posts
would imagine that the turbo pan has a hole for the turbo oil return. other than that i dotn see that there would be a difference.
The turbo pan is different, there is no oil return hole, but its shaped differetly then my carb one. The oil pickup tube is also different.
Shane
RudeZuk said:
Call me dave.....Ill buy it from you:D
Id like to get the 2wd pan looking one!
it's no different than any 2wd oil pan, the turbo block's and regular RE blocks only have 2 differences
oil port's and pistons... and the oil port's are in a regular RE block, the HP side is just plugged off, and teh return hole just needs to be drilled through, and the piston's are forged and dished... crank, rod's and bearing's and seals are all teh same...
oh yea, the oil pump's suposedly different but has the same part number :confused:
BTW shane... the 2wd pan is ON my truck... (steering clerance)
1 - 8 of 8 Posts
