1 - 20 of 952 Posts
Been building this pile for awhile, figured i'd throw up a build thread. I'll try to keep all the pictures in order since this started back in February...
A little history - Had a mildly built samurai that ended up going to a cut up, 100" wb yota axled crawler. It did good for what it was, but it left me wanting a more capable rig. So i gathered some tools and went to work.
This was my first time bending tube, notching, mig welding with gas, and using a plasma cutter. Prior to that, all i had was the all mighty flux core 110, and a 4.5'' grinder.
The goal was-
Sami 1.3/trans/6.5 case
Linked
Decent wheel base
Low COG
Tires of some sort, round preferably
ON THE CHEAP
Game on....
Heres the start
Ordered a china plasma cutter
Started on the front lower links
Started the t case cradle
Mooorrreeee
More bracing
Tear down for some welding
Starting to come together, also scored some 39s
Change of plans at this point. I decided i was going full hydro, and didnt want the 3 link. Hacked shit off and donkey punched a 4 link in.
Redid the chick with dick mount
Quick case rebuild
Ok, so shitty picture... but its the only one i have with the body on it. It didnt stay long.
I said fuck the body and decided to go all tube. If i would have known this from the start, i would've started from scratch. Building around the sami frame has been a pain in the dick.
Some more tube
Built a work bench for 50 bucks..
More tube shit
Then the plasma switch roached itself, but it still works. :laughing:
Doing some slider work
Out side shot, sittin at about ride hight
Then another change of plans. Ditched the rear 3 link, for a 4 link. That means shits gotta go, and more tube needs to go in
Started some shock hoops
Very cool build .
I always enjoy checking out "the first BIG build" for people.
The enthusiasm and ingenuity always make them fun...
One comment I would have is regarding your rear shock experience.
I am known in my circle of "main man spoons" :)laughing::laughing::laughing:) for being "anal" (no pun) to cycle the suspension over and over , mocking up and dismantling and cycling again before finalizing it.
I think you see from your experience this is a good idea.
Point B here:
Looking at your rear suspension :
1. Good call on the 4 link.
2. I would consider outboarding your upper rear shock mounts.
The way they are now and especially that they are airshocks you're gonna hate how sloppy it's gonna feel. As a bonus if they were outboarded more up there it is conceivable your "rear shock solution" may even not have been needed.
PS.
That last pic got me all impressed and I was like : Damn, that's a transformation and a half... then I read the caption... LOL!!!
totally gay never going to work :flipoff2:
the only saving grace of the entire thread is the last pic
Looks good dude! Wish I had that much wheelbase. X2 on outboarding the upper shock mounts, it'll help as previously mentioned..... 10 steps forward, 2 steps back. Pretty standard practice.
Thanks for posting this...just what I needed in the middle of trying to decide what I'm doing with my rig now. Keep it up...and keep this thread alive!
Discussion Starter · #17 ·
As for the shock placement, it can't go out up top, unless I cut more section of tube out of the main belt line. Not to say I won't do it...
Discussion Starter · #18 ·
Your sami is bad ass, I used quite a bit of ideas from you when my sami was on yota leaf springs using the offset pin for wheel base.
Discussion Starter · #20 ·
This is what I did for steering. I have a used orbital, going to a single ended tsc 6" ram, using a run of the mill Saginaw ham can pump. I used stock arms with the tie rod on top of them. Traditional high steer arms were too high and would take up some up travel.
Tie rod mount
Axle side mount
For brakes I used a non power, twin master cylinder set up. I can adjust my front and rear pressure individually. 300zx front lines, and a mixture of hard/soft lines for the rear.
I braced the pedal to the main shock hoop for peace of mind.
Rear brake set up
The wiring harness could not get any more bare bones. Just the essentials here. Batter kill, ignition, fan, and lights. I hard wired the alternator for charging. With the battery cutoff switch, there's no parasitic drain.
With everything in its place to make it drivable, I had to do it. This was the first time under its own power.
1 - 20 of 952 Posts
