1 - 14 of 14 Posts
Sure, I hear the fuel pump kicking on, and tested the line...it's gett'n it!
I checked spark...it's gett'n it!
I can't figure it out. It turns over, sounds like it wants to fire...but nothing...just wearing the optima down!
I was wondering if anybody has a code finder in the area that I could borrow to trouble shoot this thing? I wanted to get it rolling this weekend, but failed!
Come on, show me the love!
1996 Vortec 5.7L 350. New fuel pump, and new strainer...
Pat, that would be super cool. What programs do I need to do it? My wife has a laptop, I think she will let me use it. I want to try and get this thing figured out ASAP if possible. Thanks for all your help guys!
Pat here is a picture I took with the 42's on just after you left...notice the sheet is still over the motor...
YOUR PM BOX IS FULL......
WHAT WIDTH ARE YOUR AXLES?
WHAT WIDTH AND BS ARE YOUR WHEELS?
THNX RYAN
What' sthe best source for the injectors
Ironically my wife's suburban ('96 with Vortec) occasionally runs rough. I had it scanned and the diagnosis was the injectors.
Anyone have a good source for the injectors? I understand that some of the engines use an injector unit that has to be replaced as one unit ($$$). Her year/motor apparently can have inj3ctors replaced individually.
Wether they can be changed one at a time or not, you still want to change them out with a matched set. 2 injectors pulled off of the same shelf, with the same part numbers, can flow completely different numbers. The difference can be enough to think that you didn't solve your problem. Get the matched set.
· Premium Member
okay if the injector's are messed up will it at least start? because we couldn't get it to do that.............what effect will a bad oxgen sensor have on it ?..........................this would be a 96 versoin anyone know about $$ for injector's........................ltr
buddy on mine just got his 98-? vortec running this weekend.
but, it has a miss. infact when you pull #1 plug wire, it runs
the same. and, if you pull #8 plug wire, it still runs the same.
so, it's not firing on #1,8. checked timing. replaced cap and
rotor. has excellent spark at both plugs. I think it's an injector
problem.
just for FYI, my wife's 97 Astrovan, (6cyl 4.3 vortec) had an
injector problem arond thanksgiving. toot it to the dealer,
they did an "injector" cleaning. free. it's covered under warranty
for a known problem with the vortec motors. what I want to
know is what did they actually do????
there is a schrader vavle on the pressure-line going into the
vortec manifold. I'm thinking they use some sort of tool that
forces injector cleaner into all the ports. any thoughts on this?
I'm going to be calling my local dealer to find out what they did
to the wifes van...............
--Sherpa
Discussion Starter · #13 ·
Man, you guys are going to make me cry...this Vortec motor has been nothing but a huge strain on my wallet...FYI go TBI...way cheaper, and easier!
I plan on calling a few people today to help figure it out. I may not make it to TDS, but either way I want this thing running!
1 - 14 of 14 Posts
