1 - 2 of 2 Posts
Hello everybody, so i've bit the bullet and im in the process of sas'ing my toy. I was thinking about running chevy 63's front and rear. I know a lot of people run the 63 swap in the rear, just wondering if any of yall have ran chevy 63's in the front because I can't seem to find anyone with a rig where they have. If you are running 63's in the front what kind of hangars and shackles are you running? thanksa
I would think you would have the stretch the front of the frame 3 feet to make that work. That or your rear spring hangers will be touching your front shackles.
The center pin is not offset, so your front axle would be under your tranny tunnel.
The reason you've never seen anyone do it on a toyota, is because is probably impossible.
1 - 2 of 2 Posts
