Outside the frame. If you have straight shackle plates then you should have 4 150mm bolts. Did you get front & rear shackles?93TOYforME said:thanks but the bolts included with the shackles dont fit through the spring with the spacer and shackles on it. and on the 1/4" part push it outside the frame rails that much or inside frame? thanks again.
Got a ruler? 150mm = 6" and those are widebody shackles, something like this:93TOYforME said:no just front shackles not sure how long the bolts are but through the spring, spacers, and shackles it one thread left for the nut.thanks
93TOYforME said:thanks for the help. is there any advantage to the wide body shackles over the tapered ones?
That is funny, when I went to straight ones I gained about one inch more after I modified the body mount!!! :flipoff2:kiyul4130 said:either way though, when your at that much compression the non tapered will go back just barely more after the tapered would. you wouldnt be getting that much more out of it, but what your saying is true.
Plate the opening, and make sure that the rest of the mount that has the factory welds to the frame is in good shape (no cracks in the weld).93TOYforME said:okay, one more question for you the upper A arm mount is shared with the motor mount, so now with it cut off there must be a loss of structural integrety, have you guys just plated the opening in or let it be? its the 3.0 Thanks.
