1 - 6 of 6 Posts
How does it handle? Body roll? Right now my X handles beautiful with 1.5'' SL 2'' BL and 33s. What about towing a 2000lb trailer? I would probably do 35s because my truck is a daily driver. Rather SAS instead of beefing up the stock crappy steering. Might as well put that 500-600 towards a calmini kit!
Handling is going to depend on a lot of factors. Leaf, coil, coilovers, tire size, spring rates, wheel base, track width, gearing, sway bars, etc, etc, etc;
I had the same suspension set-up you have now and I can tell you that towards the end of the IFS days the handling sucked. Major body roll, shitty braking, steering that was looser than a $2 whore. It handles better & more predictably now ith the solid axle & crossover steering.
My WB is stretched to 110"+ and I am running a 70"ish track. Both help handling. 35" tires.
1 - 6 of 6 Posts
