More from yesterday. Decided it needed a few triangles. So far the cage attaches to the frame in 14 places. I hope we dont need to test them.
As Dallas has said, the plastic pieces wont be considered the inner fender. if anyone would like more clarity please feel free to email me.I'll let Chris post up, but I was told today we would not need them.
x2I hate mounting seats. That is all.
I think I spent more time on the seat mounts than I did on the rest of the cage.I hate mounting seats. That is all.
It's either that or the POS six speed manual and that ain't gonna work, so, it's the 42RLE.What tranny are you guys running? 42RLE?
No AW4 ?It's either that or the POS six speed manual and that ain't gonna work, so, it's the 42RLE.
That didn't come in TJs.No AW4 ?
OK, not up to speed with the rule book.That didn't come in TJs.
Rule book says any trans that came in that year/make/model so we only have one auto choice.Couldn't you run the 3 speed or ax-15, NV3500. Or does the trans have to be an option for that year?
Should have as in they should have offered it, or should have as in I think they did but I'm not sure?OK, not up to speed with the rule book.
But the AW4 should have came in TJ`s
As in it should have been a factory OEM offering instead of an 42. Even if it was limited to the LJ.Should have as in they should have offered it, or should have as in I think they did but I'm not sure?
It was never an option likely due to it's slightly longer length which would make the rear driveshaft very short in the stock configuration.
But, yes, I agree that it should have been adapted into the TJ from Day 1 and they should have made a shorter tailshaft adapter to shorten it up enough to work.
Wow, that's not much of a choice. Any build plans for the 42RLE? I think I saw an Atlas behind it, correct?It's either that or the POS six speed manual and that ain't gonna work, so, it's the 42RLE.
Looking back at your thread I actually like yours better than what I just built, but since our cages are a bit different your design wont work for meI think I spent more time on the seat mounts than I did on the rest of the cage.
Looking fast.
It's not in there right now, but we will be running a slightly modified version.Any reason you all aren't running the Savvy Under Armor?
The 42rle has been completely gone thru but there is not much after market support for it. Any plastic parts have been repalced. It is a electronically controlled OD so we are using the OEM computer to control it.Wow, that's not much of a choice. Any build plans for the 42RLE? I think I saw an Atlas behind it, correct?
Gerald, coming from the OEM transmission industry. The TQ convertor work was money well spent. All to often folks "beef" the transmission internals and then cheap out on properly preparing a convertor for abuse.The torque converter is were we spent money to make it last. All of the plastic has been removed and the fins brazed so they don't detonate at speed. Then balanced and tested.
