1 - 8 of 8 Posts
I'm in the very early stages of considering swapping a Scout D44 into my daughter's 82 Toy. Has anybody completed this swap? The D44 is 60.75" wide. I haven't measured the Toy axle yet. Any know the width of the Toy off the top of your head?
Would I be better off to use a Waggy front 44 due to the 6 lug pattern?
Any help or suggestions would be appreciated.
The Toy axle is about 55" wide.
I think a Waggy or Chev D44 is a better swap. Scout axle shafts are getting hard to find, a guy in my club runs one in his Jeep, and he has to buy complete Scouts just to get axle shafts. <IMG SRC="smilies/eek.gif" border="0">
Super Moderator
'82 Scrambler, '14 Rzr
Skip the Scout front 44 - it uses some oddball parts, and cutting and turning the knuckles is MANDITORY for use in a Toyota truck.
Originally posted by DRM:
<STRONG>Skip the Scout front 44 - it uses some oddball parts, and cutting and turning the knuckles is MANDITORY for use in a Toyota truck.</STRONG>
Ok then, am I better off with the Waggy or Chevy. Will the nuckles need to be rotated on these?
Super Moderator
Originally posted by Rubicrawler:
<STRONG>Ok then, am I better off with the Waggy or Chevy. Will the nuckles need to be rotated on these?</STRONG>
I am pretty sure the Waggie will work just fine <IMG SRC="smilies/smile.gif" border="0">
Thanks for the input guy's <IMG SRC="smilies/smile.gif" border="0"> I start doing my homework and check out the specs on Waggy D44's.
Super Moderator
BTW - one reason people use the Chevy is due to the cast in place spring perch issues. You can cut down a Chevy housing and keep the stock spring mounts already on the Toy.
Lets not also forget the crappy outer knuckle for anykind of highsteer.
Used a scout housing once, never again.
1 - 8 of 8 Posts
