1 - 4 of 4 Posts
When you guys swap the scout axles in an do a spring over, What are you doing to the passenger side of the front knuckle. Do you get it machined , grind it down or is there a perch out ther that you can get for that side ??
Thanks for any help...
People are just welding a perch on top of the casting. I would recommend a waggy axle instead because of its easier to do high steer and the outer axle shafts are stronger.
[ 08-21-2001: Message edited by: Rockslut. ]
yeah you need to grid alittle on the pumpkin and then weld a spring perch onto it. how much you need to grind depends on what width springs you run.
1 - 4 of 4 Posts
