You can see them in this picture, kind of. Fourth from topRustoleumWhite said:Hooper had some long add-a-leafs in his truck for the longest time.. can't remeber what brand...
Patty?!??!!?!?
Mine were the same length as the third leaf from the top.Ben W said:Hooper's look pretty short. Are you sure those were skyjackers? Skyjacker doesn't list an AAL for Scout II on their website, but that may not mean they don't make them...
Heres what I've found so far
Rancho - 22" front and rear (same part #)
Superlift - only makes short for the front
Rough Country - makes short for front and rear (same part #)
Anybody ever had the stock springs re-arched?
Yep, same front and rear. A shop here in town did it for me, a few years back, before I knew even less than the little I do now. Add a leafs and extended shackles (5.5 eye to eye).Ben W said:That might not be too bad, did you have the same ones in the rear?
Yep. 'Bout 22 years ago when I was young and dumb and broke.Ben W said:Anybody ever had the stock springs re-arched?
Front or rear? I need to look through my crap pile, Josh gave me a bunch of misc springs.Ben W said:That is exactly what I would do if I had an extra set of Scout II springs around. I may just have to go to the local spring shop and have them make me some. Unless someone has some Scout II main leaves they want to sell cheap.
Ben, if you go this route, please take some before and after measurements and let us know. I am planning on going to 35's before too long, and am curious if adding those extra mains will be enough to let me clear 35's cleanly with my SOA.Ben W said:That is exactly what I would do if I had an extra set of Scout II springs around. I may just have to go to the local spring shop and have them make me some. Unless someone has some Scout II main leaves they want to sell cheap.
If that doesn't work for you, I have a nice set of lift springs I am looking to sell....
Don't waste the money is right! Buy new springs and be happy. Re-arched, mine were $350 with an extra leaf. I had the LF spring sag after I installed the engine. I was basically fawked after that because I was broke and it was now my DD. Later, I replaced the springs with 4" Skyjerkers (rear sagged 2"scoutver5.7 said:
I had my Scout springs rearched and added Rancho aal when it was still shackle forward. Stiffest damn thang I ever rode in. Didn't take me long to buy some Rancho springs and do a RS.
My advice is don't waste your money.
My local spring shop told me they would more than happy to re arch my springs for me. But, when I asked, they also told me that they would quickly sag back to where they are now, and re arching was a temporary fix, at best. They were very reasonable about it, and freely admitted that while they offered re arching service, it was not a good way to go.Philabuster said:
Don't waste the money is right! Buy new springs and be happy. Re-arched, mine were $350 with an extra leaf. I had the LF spring sag after I installed the engine. I was basically fawked after that because I was broke and it was now my DD. Later, I replaced the springs with 4" Skyjerkers (rear sagged 2"Can't recommend them. Later I was told if I ran the hard top to get their 'helper' spring--WTF!).
Do it right the first time and you will be better off (cheaper too).
