1 - 10 of 10 Posts
Hey guys here's the question I have a buddies fixing to redo the front end on his jeep. It is a nine inch running the scout outers and cj rotors and hubs. Would he gain any width in swapping over to run the ford rotor and the ford/chevy type inner axle? If so it would be easier to do that way. Thanks
I think mine grew by one inch. I also changed the knuckles to go high steer.
The Ford and Chevy have stronger internally splined hubs
The Ford and Chevy also have better brakes if you change the knuckle
Change the CJ hubs just for the fact that the bolts on them come loose all the time, and when you break one parts go flying everywhere. New rotors for ford and chevy are probably cheaper too. The Ford outer shaft is slightly larger (stronger) than the scout, and a lot easier to find for replacement. When I did this conversion, I got chevy calipers, bracket, and spindle, Ford outers and rotors (already had chevy flat top knuckle) all for about $150.
this jeep is running chevy type brakes already, haven't had any hub problems with it since I put the jeep together for him, went with studs and locking nuts on the hubs. Is the one inch measurement overall or per side? Hopefully per side because that will about do what he has in mind without building a whole new housing and axles. thanks
I don't know about Chevy outers, but the Scout outers I have look tiny compared to a Wagoneer outer.
I don't know about that one inch number. I know that when you go from a six lug 44 to a five lug 44 using Ford/Chevy parts you gain one inch. Don't know about the Scout to Ford/Chevy swap though.
On my D44 I went from CJ D30 knuckles, CJ big brake/6bolt hubs, and Scout outers to early GM 1/2 ton outers/spindles/brakes and Ford wheel hubs.
I gained about 1.5". If you look at the wheel mounting surface in relation to the brake rotor you'll see where you get the difference.
1 - 10 of 10 Posts
