1 - 15 of 15 Posts
I want to rebuild and upgrade my D20 to twin stick and Tera 3.15's. I would like to use the Scout 20 because of its factory twin stick. Will it bolt up?? I have a 304 w/ a swapped in 2WD T-18 w/ adapter. Will I need to change anything as far as input/output, spline counts, etc?? Also, is there any difference in length compared to a CJ 20? Thanks.
-Jacob
[email protected]
-Jacob
[email protected]
I always thought all Dana 20's were the same except Ford Bronco.
rockmup said:
Nope, Scout's have a different bolt patern. Some call it a Texas style. So does the 300
Uh, Jeep Dana 20s (and 18s) also have the Texas pattern. :shaking:
About the only difference between a Jeep 20 and a Scout 20 is the shifter tower. I've used a Scout tower on a Jeep 20 to make mounting twin sticks look factory.
Ok let's get this ironed out:
Jeep 20 and Scout 20 and 1980 Scout 300 are all the same "texas" pattern. They will physically interchange with each other. The Jeep 20 and Scout 20 use the same bull gear, the Scout 300 uses a unique bull gear that fits only that t-case. The Scout 300 also has one less bolt hole on it's adapter face. If I remember, I think it's the one on top.
The Jeep 300 is a completely different pattern that is identical to the "new process" six bolt round pattern used in Dodge and Jeep vehicles. They also share the same pattern with Ford full size trucks, among others. Of course, the spline counts vary, but Jeep 300s were always 23 spline.
Hope that helps, please correct me if I am wrong.
Just to add clarification the SCOUT 300 was only made for ONE year 1980.... The Last Year ... and it is the Scout with Square headlights. If your going to start looking for a needle in a hay stack, I thought you might want to know how big the haystack is...
People who have them know what there worth...
Yes we do :smokin: .
To correct Rock Rod about the missing bolt, it is the bottom bolt that the Scout Dana 300 is missing. It also has aluminum output cover and the shift "tower?" is aluminum as well.
You can replace the Jeep Dana 20 with the scout D300 with no driveshaft mods.
1 - 15 of 15 Posts
