Hello, we were about four hours into a trail run yesterday when my D 18 transfer case started screeching in low range. It only does this in low range. Anybody else out there had this experience. Thanks in advance, James
I haven’t had that specific squeal experience, but would think worn intermediate shaft and it’s bearings are a likely culprit. I think when shifted to low range the load on the intermediate shaft and bearings changes due to driving the low range gear, and that may get it to squeal, while not doing it in hi range. Intermediate shafts are a common wear issue, especially if a low quality repro. Check out the discussion in the Dana18 sticky thread for more info on intermediate shaft quality. Guessing a bit, but that’s the first thing I’d look at.Hello, we were about four hours into a trail run yesterday when my D 18 transfer case started screeching in low range. It only does this in low range. Anybody else out there had this experience. Thanks in advance, James
The intermediate shaft spins in both high and low range. You didn't mention if the noise happens in 2 or 4wheel drive?I haven’t had that specific squeal experience, but would think worn intermediate shaft and it’s bearings are a likely culprit. I think when shifted to low range the load on the intermediate shaft and bearings changes due to driving the low range gear, and that may get it to squeal, while not doing it in hi range. Intermediate shafts are a common wear issue, especially if a low quality repro. Check out the discussion in the Dana18 sticky thread for more info on intermediate shaft quality. Guessing a bit, but that’s the first thing I’d look at.
The OP said it happen in low range only. Not sure if that TC has a low range for 2wd.The intermediate shaft spins in both high and low range. You didn't mention if the noise happens in 2 or 4wheel drive?
Sent from my SM-G960U using Tapatalk
