1 - 20 of 79 Posts
Looking for real world feed back on the two options for SD Dana 60 knuckle high steer options. There are several companies offering weld on brackets to convert the knuckles to high steer. Welding to cast can be an issue with breaking so wanting to know if anyone has had experience with this happening or not happening.
The other option is to machine them to bolt on high steer arms. This is certainly a great way to go but more costly. I would ship them off and have this service done for me.
the only time i would go with a welded high steer arm on a cast knuckle is if it was a crawler that never saw the street or more than 25mph on the trail, other wise im going with machined
When i build mine it's getting machined for bolt on high steer. You should have a local machine shop that can handle it instead of sending out, but also sending it to a vendor here with experience in this service could save you in thr long run... damn it, now I've created a non existent situation in mine own head... send it out or local???
I run a '95 BJ60, and fourwheelsupply.net machined my knuckles. I have ZERO complaints about the job they did. They've held up well for the past 4 years, running 39" Reds, 40" Treps, and now 42" Reds. I wouldn't hesitate to use their services again.
Are the 4ws arms keyed?
Explain why.
personal preference, i like feeling comfortable when bashing through the trail way faster than i should be.
ive seen multiple pictures of broken off welded arms on 05+ knuckles
sure it can be done successfully without failing but its just not for me
edit; i forgot to tell you that you sound like a demanding little faggot
The short answer is that welding dissimilar metals creates a stress concentration. Stress concentration is destroys the fatigue life. Welding dissimilar metals is about the dumbest thing you can do when life and limb is on the line.
And there's no stress concentration with studs?
After some research I have decided to get mine machined but cant decide between weaver or FWS. Im leaning more towards FWS, alittle cheaper, the arm is keyed to the knuckle and its located above the stock TRE so you can run a tie in kit. All which weaver doesn't do unless im missing something?
Fordtechguru weaver is a long time member here who has contributed much to this forum. That should factor in more than saving a couple of dollars.
Old School
I'd be surprised if the FWS kit is directly above (and parallel) to the stock TRE. I'm running 99-04 SD knuckles w/ Weaver arms on my buggy and the stock TRE end is angled. Presumably the 05+ knuckles are similarly angled?
I had a buddy who operates local shop machine some parallel spot faces on the Weaver arm and stock TRE so that I could run double shear.
And if you like good steering geometry you'll not use the Ford parts at all.
Ried C`s and knuckles set for 7-8* caster after you`ve set the pinion angle. TR to the cast in arms for Ackerman.
An even better way would be to toss the Ford center and buy an aftermarket center. That way your making the axle fit YOUR rig not the other way around.
Not a fan of the Ford at all...............Yes, its buy in is cheap but the ROI sucks.
1 - 20 of 79 Posts
