1 - 20 of 29 Posts
I am needing to clean the carbon deposits out of one of the engines on one of my trucks.
I wanted to see what people have to say about sea foam.
Also have been told about just putting water down the intake.
Also have been told I have to take off the cat, because it will get cloged with all the junk that comes out. (although, since it is a welded on cat, and I only have a stick welder, it may be a problem).
Anything else that I should look at that may help me with this, or the high compression PSI of the engine?
Thanks
Garrett
Moderating Midget
I have used Seafoam for years with my Kohler and Briggs motors to winterize of Summerize them for long periods of non-use.
Because of it, I have gone YEARS without a carb rebuild in engines that others have had to rebuild more often.
I did "Clean" a Cruiser carb with it once and it seemed to work well.
Try it, I am sold on its quality.
no strings on me
Its great stuff. It does its job.
Make sure you are in a well ventilated place because it makes a LOT of smoke if you have carbon buildup.
I ran it thru my original 1973, 95K mile IH SII engine. Tons of white smoke....but it ran a lot better afterwards.
Its like Marvel Mystery Oil.....it works.
I have been using JB Blaster from the same company that makes PB Blaster ("Weasel Piss") the killer rust break free stuff. It works good, now i have to try the SeaFoam stuff and see about it.
Used to swear on the blaster stuff until I got my first bottle of Sea Foam.
Sea Foam is the BEST I have used.
Useless tidbit...
Justice Brothers does NOT make PB Blaster even though it says they do right on the PB Blaster can. I can verify this with our distributor if you'd like...
Seafoam is fun, head to your local mall parking lot and do it on a busy day :flipoff2:
1 - 20 of 29 Posts
