1 - 19 of 19 Posts
Seals it has the answer for those holes in your vehicle when passing thru hoses, lines, wiring, ect. Check out our diaphragm expandable grommet that allows you to pass thru a plug, hose end ect and then snaps back like a rubber band to seal up on the wire, hose, ect.
Discussion Starter · #15 ·
Thanks for the positive input guys. A list of distributors can be found at the bottom of our website. Parts can also be ordered direct from the website. If you are in need of something custom, please feel free to PM me here.
Much better than the other accordion firewall grommets that are out there.
The two peice for existing stuff is not something I've seen before however. As everything has an after thought, I like that product.
1 - 19 of 19 Posts
