1 - 15 of 15 Posts
Can't use 9" in a search because it doesn't recognize the ". Can't find what I need without it so let's see if you can help me out:
In the rear...Dana 44 vs. 9". I don't need opinions as to which is better, I'm looking for the pinion height differences and overall pinion length differences. I realize that the 9" can have a companion flange, short yolk, or long yolk so let's pretend that the one I'm comparing is the short yolk.
Some of you guys have this stuff in your brain and that's where I know I can find it...
Check this site out it may have mearurements, if anything it will convince you to go with the 9" regardless.
performanceunlimited.com/illustrations/gears.html
BlueYJ
I have read that in stock form:
D-44 can handle up to a 36-inch tires
9-inch can handle up to 38-inch tires
I'm not sure what criteria this was based on, I suspect that is was by the seat of the pants. One article was in Four Wheeling Magazine
Based on axle shaft diameter, bearing size, and ring gear size the 9-inch should be considerably stronger.
I prefer a 9-inch because they are super easy to find, easy to work on, strong, and have a semi floating axle. (plus I have a bunch of parts already laying around)
Wish it was my job!
It sounds like you are trying to get a rearend that will give you the best driveline angles. A 9" has a Very short pinion, it is probably the shortest in overall distance from yoke to axle centerline, but you need to keep in mind that the 9" also has the LOWEST low pinion you can get, except a D80 as far as I know. That is, the pinion sits further below axle centerline than a D60 or D44.
I remember seeing an article that gave dimensions on the yokes compared to axle centerline for several axles, but I don't remember where?
If you get 31-spline 9 inch (or aftermarket shafts larger than that), then cool. I would say that 28-spline 9 inch shafts are comparble to 30 spline D44 shafts.
But the 9" centersection is MUCH stronger than a D44, one reason being the extra pinion support bearing, which the D44 does not have.
A D44 might live with 36 inch tires in the front, but I can't see it living in the rear unless you are driving a light rig like a buggy or Zuk.
I agree that the 9 inch is the way to go in the rear, unless you just can't deal with the low pinion, or you need a passenger offset axle. I'm building D44's front and rear for my Zuk, because I want the rear passenger offset, and I have several out of Wagoneers that I can just relocate the spring perches on and go with it.
Later!
Richard
Isn't it amazing Matt, all these responses and so many opinions about which one is better but no info you asked for. Of course I'm not much help either but had to make that observation.
The D44 pinion is 1.25" higher than the Ford 9". I have no clue on the pinion length but the 9" is shorter.
On a side note, a HP 9" will gain you 3.5" over the standard 9 but uses a 8.8 gearset and is reverse cut which weakens it quite a bit.
Perhaps if you gave us some more info we could better recommend an axle that would fit your needs.
Okay here is the real answer to the question.
The pinion on a D44 is 1.5" below centerline
vs.
The pinion on a Ford 9" which is 2.25 below centerline
The dim. from center of a 1310 yoke to center of diff on a D44 is roughly 11.5" to 12"
vs.
The dim. from center of a 1310 yoke to center of diff on a Ford 9" is roughly 10.5"
He was not asking for which axle is better he was asking for dimesional data differences.
Re: Re: Search is killing me! Compare 9" to D44
True dat. Sometimes I wonder if people read the whole question or just what they want to read
vs.
vs.
newer update on info needed, go to "hj9" for all the info you want about a ford 9in ver any other.
1 - 15 of 15 Posts
