1 - 3 of 3 Posts
Are there any detailed pictures out there showing RCI seats or other tied into the frame. I was thinking about drilling holes through the rocker panels and running 2 parallel tubes/pipes into my rock sliders and mounting the seats to these. I wouldn't mind seeing what others have done so I can start planning it out. :)
do you have a roll cage? I have seen this a lot. Where the seats tie into the cage. Yes this is a heep cage.
The reason I mentioned what I did was I have an exo basically hoops over from one side rocker tube to the other which are then bolted to the frame. So I was thinking of running pipe through holes in the rocker panel sheet metal and using that pipe to bolt the seats to. I'm just interested in what others with exos might have done to fix their seat mounts so it don't become a blender in roll
1 - 3 of 3 Posts
