ok it's time to start this puppy.....it's been in the works for about a month.....my last trip to rubicon, i broke my last knuckle stud....5 this summer:shaking: ....
soooo instead of continuing the k stud upgrade i decided to go 1ton....i've been wheelin cruiser axles (the same cruiser axles)for over 26 years so i think i deserve this trip to the dark side:cool2:
the plan:
rear axle-14 bolt dual rear wheel,4:56, detroit locker...63" as is
front- gm kingpin d60, ARB, cut down 4.5"which puts the spring perches at 27"(cruiser width) aprox 64.5"wms ...30 spline outers for now unless i can squeeze into some 35's...hence the budget
steering-WFO double hi-steer:smokin: same design as the labs stuff i have.....WFO arms shim the knuckles and loose the springs in the kingpin
brakes- 3/4 ton gm disc front and rear(15" wheels minor grinding), with line lock e-brake....corvette master
t-case-dana 300,hd output, twin stick,clocked flat....planning 4:1 if the budget allows
sbc 350 and sm465 already in my rig
springs-fj60 rears flipped*rockhugger your the man* 40series flipped infront....i have a set i used to run on the rear with tourque leafs i'll try them .....see if they work . if not i'll just go back to my current ones......i'm at 98" now with 40's front and 55's rear....i sould be at 101"
tires and wheels- 38x14.5x15 sx's 4" back space black rock crawlers
i've been aquiring parts for about a month and didn't want to post till i had everything......so i've got pretty much all of it . the 60 is of for it's "procedure" so i guess its'time to get busy
i'll start with a before pic
the plan:
