You need to 3 link for panhard(and thus, accurate roll axis).This is actually for the 4-link calculator, but I believe the values are all still the same for finding your measurements and filling in the values:
http://www.pirate4x4.com/forum/4929623-post21.html
I usually print that page out when I'm gathering my measurements and then it's a lot easier to fill in the cells
Ask and we(Pirate) will help you. What do you need? Where is your confusion/concern. Or call me if you like 818 402 6945I have a 1999 Tacoma extended cab that I recently stripped the frame of all factory suspension and removed all engine and driveline to install a 3 link front and wishbone rear. Now I think I screwed up. I also shortened the frame by 10''. I have read and read and READ and now so confused
on measurements. I cant figure out the 3 link calculators at all. I Know my wheelbase is 123.5'' and that's about it. All the things it ask for Im clueless. Im not an engineer nor a math major. So my question is there anyone out there willing to help me figure it out correctly. Id be willing to pay someone for there time. I can be reached at 256 717 9827 or ill check back here later. Thanks guys
Don't let this offer slip by
How about the ford HI PINION driver drop, I am getting close!!
Ford and dodge kind of a bitch to design/make because of the super short short side tubes?Working on it still. Sorry. Delays galore.
