The stock shackles have either shouldered bolts or sleeves that the nut tightens against. Without tightening them to the shoulder, you'll need something else to keep the nut on, it'll want to back off. Sounds like the poly bushings are a bit too thick and are getting squeezed to much. I ran stock shackle on my '85 4Runner for about 2 years w/ poly bushings and had no unusual wear. I ran stock torque on the shackle bolts.Originally posted by seajeeper:
<STRONG>I've got poly bushings with stock shackles. I torqued them to factory specs but the bushings are getting ripped up. What are you guys torquing them to? Do you leave them relatively loose (10 ft-lb) and double nut them or what?</STRONG>
