What is the longest you should make shackles??? Im not going for lift Im wanting to raise my pinion. WHt is the MAX longest you should use?? Im going for safty here guys <IMG SRC="smilies/wink.gif" border="0">
Dan
Dan
Shackle length is realy realative to your set up. with an spring pac with excesive arc you need a longer shackle to compensate for the springs length as it flatens out. Longer shackles layed back at an angle can be used to increse wheel travel and help a spring pack fully extend.Originally posted by crawlin cruiser:
<STRONG>What is the longest you should make shackles??? Im not going for lift Im wanting to raise my pinion. WHt is the MAX longest you should use?? Im going for safty here guys <IMG SRC="smilies/wink.gif" border="0">
Dan</STRONG>
ah, then cool <IMG SRC="smilies/biggrin.gif" border="0"> a shim would work. just get a centerpin with a nice long head.Originally posted by crawlin cruiser:
<STRONG>Im good for the front (cut and turned) but I fucked up the rear I set the pinion for a u-joint axle. angle= t-case angle I went to a cv and dodnt really want to mess around with re-welding. Im just looking for an easy fix thats all. thanks for the info guys
Dan</STRONG>
