1 - 20 of 107 Posts
VENDORS:
I don't want your high-tech d60's with the always wimpy ring & pinion that DOES NOT hold up to big tire, big rig, big block torque AND,
I don't want your 1950's heavy old-tech military too-high pinion, no brakes, king of the unsprung weight Rockwells that just aren't cool for rigs that are not trailer queens/pure rock buggies. Ditto for MOGS.
Who is going to be first to bring out an affordable d70/80 F with a shaved pumpkin and 37/40 spline axles with shaft / knuckle / spindle that will handle at least a 1550 series ujoint ?
Is there anyone else that wants something other than a d60 or Rockwell/Mog ? Been there, done that.
Sure thing man , check with Camo and while your'e at it I'll
take a pair built out of unobtainium . Do a search ya newb :flipoff2:
Jason R said:
so what rig is this going on that requires such ultra strength and uniqueness? :rolleyes:
Modified Class Mud Bogger that I drive on 1000 mile trips for Elk Hunting and remote wheelin and snow bogging. The d60 hasn't handled the 502/540 cu. in. abuse on irregular terrain on a sustained basis for me though its a blast to drive.
Discussion Starter · #10 ·
briejer said:
I have a 60 with a 1550 axle U-joint, it held up to 44" tires ok........soon it will get the 49" torture test
Is yours a SunRay 60 or custom ? They've got the right idea - they just need to take it to the next level with 37/40 spline shafts.
Good luck on the 49's. The IROK rounder shoulder compared to boggers is making me wait for those in 49".
i bet they will if you ask. thier shafts are all custom so there is no reason they can't make them to whatever spline count you want.
It's Sunray with a Prorock center. Talk to Lance at Sunray, they will build you a 37-40 spline, whatever you want.
Discussion Starter · #16 ·
1 - 20 of 107 Posts
