1 - 20 of 56 Posts
I put a 6" Superlift extended radius arm kit on my 1996 Bronco and it rides like a boat. I used BDS nitro shocks to try and firm it up but they are weak, you can compress them fairly easy by hand. I put Firestone airbags in the rear to help and also for towing. They did help but it's a little bouncy which I blame the shocks for also.
I think Bilsteins would help but I don't want to end up with the same issues. When I look them up they say they are valved for each specific vehicle. Some Broncos had dual front shocks so I don't know if this is part of the problem. I see B6 and B8, not sure of the difference. I want a fairly beefy shock for this truck. A normal Bilstein, I have ran them on several Jeeps and they were much harder to compress than the BDS shocks I have now.
Any help with which shock I should order?
Discussion Starter #5
Too soft, step in one side of the boat and it leans over. The bags helped a lot with the body roll but it's not just body roll, it's too soft and is in a constant state of moving around like a boat. I think shocks will fix it. That or stiffer front springs and shocks. It does have a front sway bar but there isn't one in the back.
I have a new Motorcraft steering box, Superlift pitman arm, Moog Drag link, Tie rod and ends. Moog Ball joints and Timken wheel bearings. New steering stabilizer. I did the tie rods over the knuckles. Everything is tight and it drives decent it is just too soft for my liking.
Front sway bar at least, and bilstein 5100 in medium valving should work. They are stiff although I’ve only used the universal ones you buy by length.
Discussion Starter #7
Where can I find the ones you order by length? At least a chart so I can get the part numbers. I have the measurements I got scared off when I was trying to order them and they said valved specific to the bronco. I have two sets of soft shocks already.
The 5125 are the ones I’ve dealt with. Come with 5/8 bushing ends with sleeves. Here’s a link to low ranges site that has a chart of em. The valving rates 255/70 is the firmer ones I’ve used. Those bronco specific ones you posted might work if they are long enough to work with your 6” lift.
http://www.lowrangeoffroad.com/bilstein-5125-shocks.html
Discussion Starter #12
Bilstein 5125 Shocks
Thanks!
Discussion Starter #13
I may have jumped the gun too quick. I ordered the ones I listed. Front and rear will have about 3.5" droop and the front 4 3/4" up travel and the rear 7" up. This is a daily driver that will only see mild trails. 3 1/2" droop ok?
Rolling Mod
I think you are going to be unhappy with those billsteins. They have a lot of rebound and minimal compression. In my experience with TTB and beams you want a lot more compression. You don’t need excessive rebound. I think I would probably call Accutune and get some shocks valved for the vehicle. Or call PolyPerformance. Either way get something that is rebuildable.
Are you running two or four shocks on the front?
Discussion Starter #15
I think you were going to be unhappy with those billsteins. They have a lot of rebound and minimal compression. In my experience with TTB and beams you want a lot more compression. You don’t need excessive rebound. I think I would probably call Accutune and get some shocks valved for the vehicle. Or call PolyPerformance. Either way get something that is rebuildable.
Single shocks in the front. Wouldn't the "lot of rebound and minimal compression" equate to being stiff? or do I have that backwards?
Yes it is.
short wheel base and beams make for some interesting handling, especially with a 6" superlift. not sure what to tell you other then make sure the steering angle matches the beam angle, ditch the airbags because im sure towing with that setup has to be sketchy as hell. i would also venture to say the kit is over sprung which isnt doing you any favors.
Discussion Starter #17
I bought a pair of 4" Procomp springs that have a higher rate. I am debating removing 2" of lift. The airbags have helped the most. Before the bags I felt like I could move the truck up and down 6" standing beside it holding it at the top of the door. I towed a heavy equipment trailer(empty) and a small trailer approx 1750lb and it did great with the bags. Those really aren't much of a load.
It would be great for someone wanting to ride on their couch. These are also the first 15" wheels I have had in a long time. I am sure the big sidewalls aren't helping. I am running 30 psi.
This ^
It's gonna be really hard to get a super short wheelbase twin tractor beam to ride and handle great with that much lift.
Rolling Mod
Excessive rebound or compression can make a ride stiff. Bouncy can be a result of a stiff or soft shock both. It sounds like your issue is float on compression, leading me to believe that you would like more compression. I built a f150 that rode nice with crazy amounts of compression. I’m amazed what a ttb will take.
The rebound just needs to control the spring. More spring rate requires more rebound. High rebound, high spring rate, minimal compression are common in passenger and performance cars, doesn’t translate well to trucks imo.
are you running drop brackets?
did you drop the pitman arm?
did you lift the rear or solely relying on the bags for ride height?
1 - 20 of 56 Posts
