Me 1st
ok I needed a hand reamer
mine was too long and shaft a tad to big in diameter to fit a tap t handle.
So 1st I cut it in half, try bandsaw knowing it will dull the blade.........doh! wipped off all the teeth:flipoff2:
4" cutoff wheel, 5 seconds done:smokin:
then I fire up the 135 hobart that been unused last 4 months,tack on an old 1/2 bolt that I had turned the hex head off with my lathe for another project.
! bam done
works perfect to ream out the last 5 thou
! bam done
