Great ideas here!!! Here is a simple mod an old truck mechanic showed me. He added a piece of flat stock to a combo square, this allows a mark around a corner of a truck frame.
I salvage old drill chucks from dead drills, thread them onto a 3/8"fine thread bolt and fit it with a handle...real handy for holding small parts. Also in the pic is a section of rail with some holes and a catch pan, makes a nice bench anvil.
I make knives and built a horizontal grinder with quick change wheels...with a couple simple mods this would work great for tubing as well.
Here's a shot of the other grinders...they are real handy when fabbing.
Knife vise mounted in a pocket under the table top. It rotates easily to get a comfortable working surface. I have a couple friends that use this vise to do pistol work. It's great to securely hold odd shaped pieces.
Hold down fixture for the mill, vise grip slides to allow for clamping different shaped pieces. Next to it a small aluminum with a clamp to hold smaller parts. The rotary table has a plate drilled and tapped to secure parts, there is a .250 center pin to locate off of.
Circle cutting attachment for the plasma. Drill a 1/8" center hole in work piece, slide brass collar to get desired diameter and tighten set screw.
Mike
