Thanks guys - I appreciate the kind words.
Now, I'm off to trim so sheet metal!:shaking:
Tks Greg lots of sleepless night and 3 years of frustrations and I would change a few things also lol.Looks pretty capable to me! Trust me, if I had it to do all over again, I would chose a completely different path.![]()
Sure is. I was checking his Cruiser out the other day! It's a solid looking rig.is that FATMANS FABRICATIONS in Mint Hill, NC? buddie is having a lt1 put in a cruiser there right now! Cool place!
regards, Im in stevens mill area.
aaron
Thanks Frank! Much appreciated. How was your trans working before this mod?FYI...I figured out how to provide a VSS signal for the ecu's so the transmission shifts properly without input from the SLABS. This eliminates the need for wheel speed sensors and bypasses the ABS system. I used a GPS speedo module from Intellitronix
(http://www.intellitronix.com/gps-sender.html),
It supplies the ECU the proper pulse per mile signal (8000 pmm) that the ECU is looking for input as road speed. Use the Pink/Green (K/G) wire on connector C0504 pin 3 (It's the black connector on the slabs unit). Cut the wire, splice a connector on and feed the output of the speedo to the this wire, (Don't feed back to the connector) This will feed the rest of the systems looking for a VSS feed (Road speed) signal.
Works great, I have a accurate speedo and the transmission shifts properly...
Um, yes. I kinda removed most of the sheetmetal from the bulkhead forward on my rig, so, yes, I can safely say I have removed a LOT of reinforcement, and on an RRC which does have spring-assist hinges.I dunno, even without sprung hinges that looks like a lot of factory reinforcement has been removed. Are you running a hood with that much structural support removed and wheeling serious trails with it?
Now you're talking my friend!Now, I'm off to trim so sheet metal!:shaking:
After all that brainstorming, it's finally resolved! Nice elegant solution.FYI...I figured out how to provide a VSS signal for the ecu's so the transmission shifts properly without input from the SLABS. This eliminates the need for wheel speed sensors and bypasses the ABS system. I used a GPS speedo module from Intellitronix
Use the Pink/Green (K/G) wire on connector C0504 pin 3 (It's the black connector on the slabs unit). Cut the wire, splice a connector on and feed the output of the speedo to the this wire, (Don't feed back to the connector) This will feed the rest of the systems looking for a VSS feed (Road speed) signal.QUOTE]
Left you a VM. So, I'm cutting the Pink/Green wire, or just tapping a lead off of it, and then connecting the speedo sending unit (Intellitronix) to this wire?
That way the signal from the GPS unit is sending the proper signal into the SLABS so it thinks the wheels sensors are still connected - correct?
The answers you seek are in the ETM.Use the Pink/Green (K/G) wire on connector C0504 pin 3 (It's the black connector on the slabs unit). Cut the wire, splice a connector on and feed the output of the speedo to the this wire, (Don't feed back to the connector) This will feed the rest of the systems looking for a VSS feed (Road speed) signal.QUOTE]
Not currently but lemme see what I can do.I like that front bumper. :smokin: Do you have any more pics of it? Pics straight from the side and straight from the top would be awesome.
