1 - 5 of 5 Posts
Not sure if that is the larger holes, should be. I did mine with a 3/8" and reamed it out a little. actual size should be 7/16th".
Banned
Chad
I haven't confirmed these yet but I combiled this info from another recent post. Your drive shaft bolts should be 10 mm and I think Toyota make the holes 10.5mm but again I haven't confirmed this myself. When I drilled out my flange I used a 13/32 (.406") dia since 10 mm is (.394").
Toyota Bolt pattern listing:
U-Joint pattern '79 thru '83 (maybe early '84)
3.340"[84.8mm] Bolt Cirlce
2.200"[55.9mm] x 2.525"[64.1mm] Rectangular pattern
(4) holes .335"[8.5mm] Diameter
CV-Joint pattern '79 thru '83 (maybe early '84)
3.575"[90.8mm] Bolt Cirlce
2.350"[59.7mm] x 2.670"[67.8mm] Rectangular pattern
U-Joint pattern '84 and later
3.323"[84.4mm] Bolt Circle
2.350"[59.7mm] x 2.350"[59.7mm] Square pattern
(4) holes .413"[10.5mm] Diameter
CV-joint pattern '84 and later
3.636"[92.4mm] Bolt Cirlce
2.350"[59.7mm] x 2.775"[70.5mm] Rectangular pattern
1 - 5 of 5 Posts
