1 - 12 of 12 Posts
Anyone know the size of the socket for a rear D60 to get the nut off so I can repack the bearings and do the brakes.
Easy
I tried the auto parts clerk, all I got was that deer in the headlights look from the idiot. I'll try 2&9/ and see what happens.
Easy
I have a 1990 Dodge Dana HD ff 60 and the hub nut size is 2 1/2" <IMG SRC="smilies/smile.gif" border="0">
[ 09-18-2001: Message edited by: webilt ]
i'm trying to figure this out myself, best i can tell is that its a 2 5/16 on my FF doge D60 rear. but i can't find a socket that big so i don't know for sure. anyone know what size it is and where to get one?
What year, make and model was the 60 from?
My 60HD specs a 2.5" socket, but when I measured the nut, it was 2 9/16"
2-3/8", 2-1/2", and 2-9/16" are all common sockets for D60s
Discussion Starter · #10 ·
Mine ended up being a 2&9/.
Just for reference, it's out of a 79 1ton ford
Easy
Need to buy the socket designed for the axle, not because it is a weird size or anything, but because a normal socket won't fit between the hub and the nut. It will be a painted stamped steel socket. It's cheaper than a quality 3/4"drive socket of the same size. You can use a regular socket, but you have to grind the shit out of it.
If you go to a good parts store, tell them what axle it is, they will supply you with the correct socket. I bought mine from Dodge dealership a couple years ago for about $20, and they might just loan you one.
1 - 12 of 12 Posts
