is the sky jacker rock ready 8 inch lift, a good lift kit is it strong i want to run 37 inch tires with it
Proper punctuation makes a sentence easier to read.what if i cut the fenders i would cut the rear all the way back to the hatch
That could work or just stack hockey pucks til you reach the desired height, that should do it. :shaking:Why do a 3 inch body lift when you can get a good strong 8 inch body lift. It is way cheeper then getting a suspension, and it will work way better.
im having a set off dana 60 built . waiting on clemson 4 wheel to call me back with the price and stuff.8" of lift????? Find some 40" - 42" tires if you are going that big.
Get some real axles too.
Better yet fab your lift.
Read Me
I prefer using tubing and then duct taping hockey pucks on each end to dampen vibration...always concerned about those pucks coming apart when you stack them 8, 10, 12 inches tall.That could work or just stack hockey pucks til you reach the desired height, that should do it. :shaking:
Its easier to fab your own stuff then you thinki would fab my lift but i do not have time i only get the weekends off.
WTF?Its easier to fab your own stuff then you think
DAMN! Drag link and track bar are perfectly parallel and almost completely flat, that is one amazingly well setup suspension!! :smokin:Its easier to fab your own stuff then you think
I see your jeep is coming along nicelyIts easier to fab your own stuff then you think
FYI i would only recomend the 8" lift if you go through water and dont want a snorkel. i have the clayton 8" and here in FLorida it works great, i use the AFE intake so i need the height to go through water and it works great on the small mine pits here also.is the sky jacker rock ready 8 inch lift, a good lift kit is it strong i want to run 37 inch tires with it
I've had this lift for two years and no really big problems. I noticed the driver side upper control arm bracket bolts backed out a little bit. I had just welded the hell out of it.:usa: With 35's and some trimming up front and I had trimmed the rear to the pinch seem. It works really good. It has scrared my tires some:nuke: Over all Im very happy with the set up. Good Luck.Id go with a Full-Traction 6" long arm, and do some trimming...you will be happier, and its a better setup, imo.
