1 - 2 of 2 Posts
I was told that sky's shock mounts weren't designed to be used with their YJ kit and need slight modification to be used in this application because the YJ kit pushes the front axel forward a little. Does anyone know exactly what needs to be modified? And does someone have pics?
with my yj kit from there it was a mess but i figured out that with the shock mounts you need to put the mounts on the "wrong side" so actually the mount goes to the front of where the stock mount is or left on the right side and right on left side hope that helps i've got some pictures somewhere
1 - 2 of 2 Posts
