1 - 13 of 13 Posts
How many have you had, location of cuts, etc? Just curious on how they are holding up now that people have had them for a while.
I cut one this weekend that was ~11 months old. Two 2" gashes on the inside sidewall, did it spinning on some chert rock (similar to flint). 20 plugs to fill one hole, gave up on plugging the other but it was the same size.
tunedportcj5 said:
OUCH!! :eek:
Were you at the quarry? Where did you slice the tire?
I got a pretty good slice on one of my boggers. About 5" long and can barely see the cords... from riding out there
Later,
David
Yes at the quarry. Playing to the right, at the bottom of the big hill climb
I was courious as to why one of my Krawlers started loosing air after my bad tumble at the Farmington Finals and found out when I removed it's (early version) Allied beadlock rim.
The leak was due to debris being shoved underneath the bead seal but even worse, the sharp outer edge of the rim's ring seat had cut deeply into the rubber of the inside perimeter of the same area ... down to the steel belting!
I looks like Allied spotted this problem and my new 8 lug versions all have a nice lathe cut bevel on the outer edge of their ring seats now. But I thought I'd report that sharp bead lock rim edges can cut and seperate the Krawler's soft compound rubber.
In my experience, the steel beadlock sharp edge thing only occurs when a ring has loosened up and there is considerable movement- I've been watching this as BFG asked me to.
I've sliced my sidewalls often, but only once though the cord, similar to my experience with many of the Swampers I've owned.
Disney OK is hell on tires, strangely enough, the one tire I sliced thru was at Farmington, laying on my side trying to save a roll at the money pit. It was about a 2" slice, I had it vulcanized and use it for my spare.
Jone's tires in Springdale, $35, 479 751-2082
Ken
A couple of my Krawlers have large(6") gashs the sidewalls.None have penetrated all the way through and they seem to hold up under heavey sidewall abuse even with the gashs.All the damage is from very clean, sharp edged local, granite.
I reckon endo-ing onto the edge of a rim hard enough to push slickrock rubble under a (tight) beadlock's ring would qualify as "considerable movement", Ken. :flipoff2:
So, if one does runs low pressure on rugged terrain it won't hurt to smooth over any sharp edges on your bead lock's ring seat if they came that way.
1 - 13 of 13 Posts
